USB oscilloscope and spectrum analyzer, which one?
neazoi
Advanced Member level 6
Greece
Hello, because of space limitation, I want to buy a USB oscilloscope and spectrum analyzer.
My main interest is at HF work, so 30MHz analogue bandwidth at least. a 100-200MHz would be better so as to be able to measure harmonics as well.
Which ones would you suggest for:
100-200MHz analogue bandwidth.
scope combined with spectrum analyzer
usb2
dual channel
relatively low budget <200Euros?
Other specs?
How about this one?**broken link removed**
Or this one for a little more Hantek 6254BD ?
For what its worth - we've complied some mfg data in a product finder here - https://products.designworldonline.com/oscilloscopes.html
The only usb scope under $300 is the MSO-19, which is only 60MHz, not good.
The Hantek 6254BD is 1G sample and it can do to 250MHz at a reasonable price. But I cannot find any info on the datasheet (attached for the 6000 series scopes) about the single shot bandwidth. Also it is anoying it does not have a 50R input impedance like my
HP 54520A does. But I guess I can do measurements at 50R by shunting a 50R at the input of the scope.​
Other such scopes?
  • HT6004BX_Manual.pdf
