bhl777
Full Member level 6
Hi all, I am looking for some low-temperature electronics systems applications. Would anyone give me some examples that circuits need to operate at low temperature (for example, -70C) to room temperature? It is better than the circuits are not required to operate at a higher temperature than room temp.
For instance, do some avionics circuit blocks need to operate at low temperature when the airplanes are in the air, but not necessarily need to work on the ground?
Thank you!
Thank you!
