Point to point coaxial cable communication link
mmuj
Junior Member level 3
Hi
I am working on point to point communication system over dedicated coaxial cable.
Required Data rate = 100kbps
cable length = 5km
I am looking for suggestion/design ideas
In one of my previous projects I used wire line modem (CMX866) successfully over similar distance but baud rate was 2400.
Can I use two DSL modem ICs for such communication? are DSL chipset ICs available for Digikey/Farnell? i couldn't find any from product profile of TI, Analog or ST etc.
I know Broadcomm is a key player in this market but they don't have good reputation for supporting small volume/ niche market customers.
Any other ideas?
mmuj
If you intend to use a coaxial cable, you have to determine the accepted attenuation due to either cable connections as well to the cable losses, which is not small. Each cable type ( e.g RG-59, RG-6, etc… ) is suited to work with determined range. Although the coaxial cable has a good performance in terms of SNR, I would consider using an optic fiber for 5Km at 100Kbps.
