+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 2
    Points: 96, Level: 1
    Join Date
    Apr 2016
    Posts
    Points
    96
    Level
    Evaluate leakage field power in CST
    I'm using CST Microwave Studio to simulate a thin square cavity resonator, one face of which has a grid of holes. I want to evaluate the amount of field leakage, to relate it to the hole size. This involves quantifying the power transfer through a plane, but at this stage I do not even know how to write out the field intensity values on a specified plane. I would be grateful for some pointers.
    Thanks, Gib
    •   AltAdvertisement
  2. #2
    Member level 2
    Points: 1,561, Level: 9
    Join Date
    May 2012
    Posts
    49
    Points
    1,561
    Level
    9
    Re: Evaluate leakage field power in CST
    Hi Gib,
    The power flow should be the integral of the Poynting vector through the specified plane.
    To do this in CST MWS, you should first define an analytical face (the face is just for analysis, and does not interfere with the model) at the plane you are interested in.
    The power flow monitor should be activated prior to running the simulation.
    When the simulation is complete, you should be able to evaluate field on face, in this case the integral of the power flow monitor.
    Hope that helps!
    •   AltAdvertisement
  3. #3
    Newbie level 2
    Join Date
    Apr 2016
    Posts
    Points
    96
    Level
    Quote Originally Posted by gyz182 View Post
    Hi Gib,
    Hope that helps!
    Hi gyz, thanks for that poynter ;) Since I posted the query I discovered how to evaluate power flow. It's a bit hazy now, but I seem to recall that upgrading to the latest CST version clarified things.
    Cheers, Gib
