raman00084
Full Member level 6
can any one explain the ct current ratio and turns ratio. in my ct the name plate is as follows ratio 10/5 what it is current are turns ratio.
if i make 2 primary turns then what happens?
As shown in the datasheet linked by FlapJack in post #9, this isn't always the case, particularly for CTs with low primary current and 5A output (to be connected to energy meters etc.). But we can presume that the intended operation, including the number of primary turns is clearly indicated in the mounting instructions. In so far there should be no need to count secondary turns, which is a bit difficult with molded windings. Measuring inductance or current ratios is a last resort of course.You usually only ever do one primary turn with a Current transformer.
