Suitable TRIAC to replace contact in thermostat (24VAC) ?
Jester
Full Member level 6
Well, first of all, you have to know exactly what your load requirements are.
You already have the first requirement (24VAC) and as such, you can select a lower voltage rated Triac.
But what is the load current? I suspect it will be around 1 amp, but you may want to check it out.
Anyways, a safe bet would be a 200V, 4A Triac. They are ubiquitous and low cost.
Reactions: Jester
    Jester
A 600V 8A triac is certainly an overkill for one who needs to switch 24V at 1A.
But then you also consider:
1. It is easily available and the one want is not;
2. You may not need an heatsink even;
3. You can proudly boast about your conservative designs;
4. No doubt it will be an improvement over the original.
Reactions: Jester
    Jester
