GURKE
Newbie level 2
Hi guys,
I bought this TFT: **broken link removed**
I think it uses the ILI9325.
Here I found some code to use this display with an atmega32:
https://translate.google.com/transl...t_shield_2_4_atmega32/0-77&edit-text=&act=url
I'am using an AtMega1284p at 16Mhz.
The initialization-routine:
The display starts white and changes to colorfull and flickers. It's not red as i should be.
Please help guys
void LCD_ILI9325_Init(void)
unsigned char i;
unsigned int f;
LCD_DATA_OUT;
LCD_DATA_PORT = 0xFF;
LCD_CLT_DDR = 0xFF;
LCD_CS_H;
LCD_RS_H;
LCD_WR_H;
LCD_RD_H;
LCD_REST_H;
_delay_ms(50);
LCD_REST_L; //??
_delay_ms(50);
LCD_REST_H;
_delay_ms(50);
LCD_WriteReg(0x0001,0x0000);//çåðêàëüíî âåðòèêàëü (0x0100)
LCD_WriteReg(0x0002,0x0700);
LCD_WriteReg(0x0003,0x1030);//ïðåîáðàçîâàíèÿ RGB â GBR, ñòðî÷íîé ðàçâåðòêè
LCD_WriteReg(0x0004,0x0000);//çåðêàëüíî âåðòèêàëü (0x0000)
LCD_WriteReg(0x0008,0x0207);
LCD_WriteReg(0x0009,0x0000);
LCD_WriteReg(0x000A,0x0000);
LCD_WriteReg(0x000C,0x0000);
LCD_WriteReg(0x000D,0x0000);
LCD_WriteReg(0x000F,0x0000);
//power on sequence VGHVGL
//Ïèòàíèÿ íà ïîñëåäîâàòåëüíîñòè VGHVGL
LCD_WriteReg(0x0010,0x0000);
LCD_WriteReg(0x0011,0x0007);
LCD_WriteReg(0x0012,0x0000);
LCD_WriteReg(0x0013,0x0000);
//vgh
LCD_WriteReg(0x0010,0x1290);
LCD_WriteReg(0x0011,0x0227);
//vregiout
LCD_WriteReg(0x0012,0x001d);//0x001b
//vom amplitude
// Ïî àìïëèòóäå
LCD_WriteReg(0x0013,0x1500);
//vom H
LCD_WriteReg(0x0029,0x0018);
LCD_WriteReg(0x002B,0x000D);
//gamma
// Äèàïàçîí
LCD_WriteReg(0x0030,0x0004);
LCD_WriteReg(0x0031,0x0307);
LCD_WriteReg(0x0032,0x0002);//0006
LCD_WriteReg(0x0035,0x0206);
LCD_WriteReg(0x0036,0x0408);
LCD_WriteReg(0x0037,0x0507);
LCD_WriteReg(0x0038,0x0204);//0200
LCD_WriteReg(0x0039,0x0707);
LCD_WriteReg(0x003C,0x0405);//0504
LCD_WriteReg(0x003D,0x0F02);
//ram
LCD_WriteReg(0x0050,0x0000);
LCD_WriteReg(0x0051,0x00EF);
LCD_WriteReg(0x0052,0x0000);
LCD_WriteReg(0x0053,0x013F);
LCD_WriteReg(0x0060,0x2700);//çåðêàëüíî ãîðèçîíòàëü (0xA700)
LCD_WriteReg(0x0061,0x0001);
LCD_WriteReg(0x006A,0x0000);
LCD_WriteReg(0x0080,0x0000);
LCD_WriteReg(0x0081,0x0000);
LCD_WriteReg(0x0082,0x0000);
LCD_WriteReg(0x0083,0x0000);
LCD_WriteReg(0x0084,0x0000);
LCD_WriteReg(0x0085,0x0000);
LCD_WriteReg(0x0090,0x0010);
LCD_WriteReg(0x0092,0x0600);
LCD_WriteReg(0x0093,0x0003);
LCD_WriteReg(0x0095,0x0110);
LCD_WriteReg(0x0097,0x0000);
LCD_WriteReg(0x0098,0x0000);
LCD_WriteReg(0x0007,0x0133);
LCD_WriteComand(0x0022);//Start to write to display RAM
//paint screen red
for(i=0;i<2;i++)
for(f=0;f<38400;f++)
LCD_WriteData(RED);
Please help guys
