Results 1 to 11 of 11
    Points: 7,065, Level: 20
    Jun 2009
    California
    1,308
    7,065
    20
    How to fix FatFS compilation on STM32 ?
    Guys,
    I tried to compile FatFS on STM32 but got this error, how to fix it ?
    thanks
    ..\Middlewares\Third_Party\FatFs\src\diskio.c(443): error:  #167: argument of type "const BYTE *" is incompatible with parameter of type "BYTE *"
    Points: 260,224, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    Re: How to fix FatFS compilation on STM32 ?
    Probably a problem of compiler options.
    FatFs is using const attribute e.g. for write buffers, if you want to assign a non constant object to it, you need either to relax type checking or use a type cast.
    Jun 2009
    California
    1,308
    7,065
    20
    Here's the function :
    #if _USE_WRITE == 1
    DRESULT disk_write(BYTE pdrv,
      const
    	BYTE *buff, DWORD sector, UINT count)
      DRESULT res;
    	if (pdrv || !count) return RES_PARERR;
    	if (Stat & STA_NOINIT) return RES_NOTRDY;
    	if (Stat & STA_PROTECT) return RES_WRPRT;
    	if (!(CardType & CT_BLOCK)) sector *= 512;	/* Convert to byte address if needed */
    	if (count == 1) {	/* Single block write */
    		if ((send_cmd(CMD24, sector) == 0)	/* WRITE_BLOCK */
    			&& xmit_datablock(buff, 0xFE))
    			count = 0;
    	else {				/* Multiple block write */
    		if (CardType & CT_SDC) send_cmd(ACMD23, count);
    		if (send_cmd(CMD25, sector) == 0) {	/* WRITE_MULTIPLE_BLOCK */
    			do {
    				if (!xmit_datablock(buff, 0xFC)) break;
    				buff += 512;
    			} while (--count);
    			if (!xmit_datablock(0, 0xFD))	/* STOP_TRAN token */
    				count = 1;
    	deselect();
    	return count ? RES_ERROR : RES_OK;
     	  //res = disk.drv[pdrv]->disk_write(buff, sector, count);
      //return res;
    #endif /* _USE_WRITE == 1 */
    I got error on :
    How can I do that ?
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    In recent fatfs implementations that I reviewed, xmit_datablock() has also const BYTE * buff parameter, thus the problem doesn't occur.
    I'm not sure if GCC has a global option to relax type checking for const pointers. I would use a type cast (BYTE *).
    Jun 2009
    California
    1,308
    7,065
    20
    if I put :
    static
    int xmit_datablock (
    	  const BYTE *buff,	/* 512 byte data block to be transmitted */
    	BYTE token			/* Data/Stop token */
    	BYTE resp;
    	if (!wait_ready(500)) return 0;
    	xchg_spi(token);					/* Xmit data token */
    	if (token != 0xFD) {	/* Is data token */
    		xmit_spi_multi(buff, 512);		/* Xmit the data block to the MMC */
    		xchg_spi(0xFF);					/* CRC (Dummy) */
    		xchg_spi(0xFF);
    		resp = xchg_spi(0xFF);			/* Reveive data response */
    		if ((resp & 0x1F) != 0x05)		/* If not accepted, return with error */
    			return 0;
    	return 1;
    I got :
    ..\Middlewares\Third_Party\FatFs\src\diskio.c(237): error:  #167: argument of type "const BYTE *" is incompatible with parameter of type "uint8_t *"
    because of :
    /* Send a data block fast */
    static
    void xmit_spi_multi (
    	 uint8_t *p,	/* Data block to be sent */
    	UINT cnt
    	while(HAL_SPI_GetState(&hspi2) != HAL_SPI_STATE_READY);
    	HAL_SPI_Transmit(&hspi2,p,cnt,100);
    /* Receive a data block fast */
    static
    void rcvr_spi_multi (
    	BYTE *p,	/* Data buffer */
    	UINT cnt	/* Size of data block (must be multiple of 2) */
    	HAL_SPI_Receive(&hspi2,p,cnt,100);
    I don't think I can change uint8_t *p ....to const BYTE....because it's from HAL STM32CubeMX...
    I change to BYTE, I got :
    ..\Middlewares\Third_Party\FatFs\src\diskio.c(237): error:  #167: argument of type "const BYTE *" is incompatible with parameter of type "BYTE *"
    static
    	 const BYTE *p,	/* Data block to be sent */
    	UINT cnt
    ..\Middlewares\Third_Party\FatFs\src\diskio.c(132) : error: #167: argument of type "const BYTE *" is incompatible with parameter of type "uint8_t *"
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,224
    100
    Just normal C stuff...
  7. #7
    Jun 2009
    California
    1,308
    7,065
    20
    How can I fix it without changing the variable type ? thanks
  8. #8
    Full Member level 3
    Points: 4,634, Level: 16
    Apr 2001
    California, USA
    188
    4,634
    16
    Have you tried to cast const BTYE * to (BYTE *)?
  9. #9
    Jun 2009
    California
    1,308
    7,065
    20
    Quote Originally Posted by cfant View Post
    static
    	BYTE resp;
    		xchg_spi(0xFF);
    			return 0;
    	return 1;
    const BYTE *buff to (BYTE *buff) ??
    It works fine if I erased "const"
    //#if	_USE_WRITE
    static
    	BYTE resp;
    		xchg_spi(0xFF);
    			return 0;
    	return 1;
    I got this error if I deleted all const :
    ..\Middlewares\Third_Party\FatFs\src\ff.c(2728): error: #167: argument of type "const BYTE *" is incompatible with parameter of type "BYTE *"
  10. #10
    Points: 7,828, Level: 21
    Jan 2015
    1,097
    7,828
    21
    Did you also update the declaration in the header?
    Susan
  11. #11
    Full Member level 1
    Points: 2,800, Level: 12
    gamegurus's Avatar
    Jan 2005
    97
    2,800
    12
    Consider using CMSIS compliant ARM library to avoid such issues.
