shsn
Junior Member level 3
Hello
I came across a PCB from a junk bin with interesting high current stud/connector. The stud has size of M6 (6mm diameter) and is magnetic so I assume it's copper-plated steel. The bottom has some sort of elliptical shaped plate.
Does anyone where I can find the same or similar connector? I never seen such connector on a PCB.
Thanks
Thanks
