peeyushsigma
Member level 4
- Joined
- Apr 15, 2012
- Messages
- 77
- Helped
- 19
- Reputation
- 38
- Reaction score
- 17
- Trophy points
- 1,288
- Location
- Bengaluru, Karnataka, India
- Activity points
- 1,773
Hello everyone,
I am using PWM to control a proportional solenoid valve(12 V,340mA) to control air flow rate. The control system is working but the coil of the solenoid is getting very hot. I want to reduce the heat generated in the coil.
After searching on the internet. I found that If I use PWM current control then I can reduce the heat loss in the coil. Here is an Application note of MAXIM which describes how to use LED driver to control Solenoid Valve.
My question is ..Can i Use any 12 V 350mA LED driver (with pwm dimming ) to control the solenoid (Inductive load with flyback diode). and will this reduce the heat loss??
Proportional Valve Datasheet
