visor
Newbie level 2
Hi all,
i'm having some issues with the design of a patch antenna on a Duroid 5880 substrate (2.2 electric constant) thickness=1.575mm, solution frequency 5.8Ghz.
i've computed the following values:
The width of the patch (Wp) is:20.4458mm
The lenght of the patch (Lp) is:16.5008mm
The inset feed point (Fi) is:6.0932mm
The width of the feed line (W0) is:4.8514mm
The lenght of the feed line (L0) is:9.4530mm
The gap of the feed line (Gfl) is:0.11929mm (i got some doubt on this value)
The minimum lenght of the ground plane is:25.9508mm
The minimum width of the ground plane is:29.8958mm
The Zin of the patch is:313.6511ohm
this computation are made in order to obtain a 50ohm matchin but when i plot the report on HFSS doing:
create a new report--->rectangular plot--->terminal Z parameter---> Mag
i'm only able to obtain a |Zin|=35ohm can someone say if my data are right and if not where i'm wrong? what can i do in order to have a good matching at 50 ohm? in order to obtain a better return loss it's a good choice to trim the lenght of the patch?
