+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Member level 3
    Points: 897, Level: 6
    Join Date
    Apr 2013
    Bangalore
    Posts
    54
    Points
    897
    Level
    suggestion for best synthesis tool for asic design
    Hi
    I want to know best synthesis tool for asic design. From web i have listed some like
    1. Design Compiler by Synopsys
    2. Encounter RTL Compiler by Cadence Design Systems
    3. HDL Designer by Mentor Graphics
    4. TalusDesign by Magma Design Automation
    I know it might be difficult to say best because it might depends on what to implement.
    still what are the points or features to consider while choosing synthesis tool
    thanks
    •   AltAdvertisment
  2. #2
    Advanced Member level 1
    Points: 5,383, Level: 17
    Join Date
    May 2005
    Posts
    452
    Points
    5,383
    Level
    17
    Re: suggestion for best synthesis tool for asic design
    1 or 2.
    3 isn't a synthesis tool, isn't an editor I think.
    4 Magma don't exist any more.
    1 members found this post helpful.
  3. #3
    Member level 3
    Join Date
    Apr 2013
    Bangalore
    Posts
    54
    Points
    897
    Level
    Quote Originally Posted by jbeniston View Post
    1 or 2.
    thanks
    In choosing between design compiler and encounter RTL what are the points / features i should consider? In terms I want to know what points i should check while choosing synthesis tool for asic design?
    •   AltAdvertisment
  4. #4
    Points: 7,946, Level: 21
    Achievements:
    7 years registered Created Blog entry
    dpaul's Avatar
    Join Date
    Jan 2008
    Germay
    Posts
    1,180
    Points
    7,946
    Level
    21
    Blog Entries
    Are you working anywhere? If yes, does your company have licenses for all the tools you have mentioned?
    Typically a design teams will follow just one EDA tool vendor.
    Synopsis for years have been the de-facto. Cadence tools are less expensive. Depends on the company budget, comfortably of the engineers and the decision of the tech-lead/principal design engineer/manager.
    If you are entrusted by your mgmt. to take a decision then you need to compare the tools (go to the relevant websites/use data-sheets and compare the features) and see how it will useful for *your design* (which none of the EDA board members will know).
    FPGA enthusiast!
  5. #5
    Join Date
    May 2005
    Posts
    452
    Points
    5,383
    Level
    17
    Quote Originally Posted by seeker_123 View Post
    You could do an evaluation of each on your design, comparing QoR (timing, area, power). Cost will no doubt be important too.
    There's not a huge difference between them really. Either will do the job.
    •   AltAdvertisment
  6. #6
    Full Member level 3
    Points: 1,923, Level: 10
    Join Date
    Nov 2012
    Bangalore
    Posts
    169
    Points
    1,923
    Level
    10
    I will suggest design compiler only.
  7. #7
    Full Member level 5
    Points: 2,228, Level: 10
    englishdogg's Avatar
    Join Date
    Jan 2012
    India
    Posts
    249
    Points
    2,228
    Level
    10
    Mentor has a solution in the same space, RealTime Designer nextgen physical synthesis tool says from their website. Worth a check
    Last edited by englishdogg; 23rd September 2015 at 06:45. Reason: Correcting English
    Sharing Knowledge only increases it further...
    cheers
    ed !!
