component becomes invisible in dxp
banner
iran
Hi there,
I have a simple but annoying problem with DXP that i have recently installed. when I select an object to move, it becomes invisible when I press the mouse button and it become visible again when I release the mouse button. it happens also when I want to draw a Track between two pads. I have never had this problem with DXP.
would you please help me to change the setting in a way that every thing is visible all the time?
Thanks in advance,
What version are you using? Since v. 15.1.9 I also have the problem that components sometimes disappear when I rotate them. The same happens to schematic pins in the schematic library editor when I rotate them.
this is version 9.3.1. is there anyway?
I don't think it's a feature, I've never encountered it myself when I was using v 9.3. It's either a bug or a graphics glitch, so you could try updating your graphics card driver.
Turning off the "Use Alpha Blending" option should resolve your problem. This is a common problem on several of our workstations.
You can find it under DXP > Preferences > PCB Editor > Display
Reactions: banner
    banner
