Results 1 to 7 of 7
    Newbie level 3
    Points: 25, Level: 1
    Apr 2015
    25
    If I have 12 bits each 4 represent a number in binary, how do i convert it to binary?
    How can I convert a 12 bit binary number where each 4 bits represent a character into an 8 bit binary number?
    Example: 12 bit number : "001001000011" ==> 2,4,3 and I want to convert it to 243 ==> "11110011"
    any help please?
    What I did but still haven't reached a right answer:
    Code VHDL - [expand]
    8
    9
    10
    11
    12
    13
    14
    15
    16
    17
    18
    19
    20
    21
    22
    23
    24
    25
    26
    27
    28
    29
    30
    31
    32
    33
    34
    35
    36
    37
    38
    39
    40
    41
    42
    43
    44
    45
    46
    47
    48
    49
    50
    51
    52
    53
    54
    55
    56
    57
    58
    59
    signal output1, output2, output3 : integer range 0 to 9;
    signal output11, output22 : integer range 0 to 255;
    begin
    process(clk)
    begin
    if(clk'event and clk='1') then
        case input(11 downto 8) is
            when  "0000" => output1 <= 0;
            when  "0001" => output1 <= 1;
            when  "0010" => output1 <= 2;
            when  "0011" => output1 <= 3;
            when  "0100" => output1 <= 4;
            when  "0101" => output1 <= 5;
            when  "0110" => output1 <= 6;
            when  "0111" => output1 <= 7;
            when  "1000" => output1 <= 8;
            when  "1001" => output1 <= 9;
            when  others => output1 <= 0;
        end case;
        case input(7 downto 4) is
            when  "0000" => output2 <= 0;
            when  "0001" => output2 <= 1;
            when  "0010" => output2 <= 2;
            when  "0011" => output2 <= 3;
            when  "0100" => output2 <= 4;
            when  "0101" => output2 <= 5;
            when  "0110" => output2 <= 6;
            when  "0111" => output2 <= 7;
            when  "1000" => output2 <= 8;
            when  "1001" => output2 <= 9;
            when  others => output2 <= 0;
        end case;
        case input(3 downto 0) is
            when  "0000" => output3 <= 0;
            when  "0001" => output3 <= 1;
            when  "0010" => output3 <= 2;
            when  "0011" => output3 <= 3;
            when  "0100" => output3 <= 4;
            when  "0101" => output3 <= 5;
            when  "0110" => output3 <= 6;
            when  "0111" => output3 <= 7;
            when  "1000" => output3 <= 8;
            when  "1001" => output3 <= 9;
            when  others => output3 <= 0;
        end case;
    end if;
    end process;
    output11 <= output1*100;
    output22 <= output2*10;
    finaloutput <= output1+output2+output3;
    output<= std_logic_vector(to_unsigned(finaloutput,8));
    Points: 260,203, Level: 100
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,203
    100
    Re: If I have 12 bits each 4 represent a number in binary, how do i convert it to bin
    What do you mean by "still haven't reached a right answer"? What are your requirements for a "right answer"?
    Altough the BCD to binary operation can be described in less lines using ieee.numeric_std conversion functions, the shown code should basically work.
    Newbie level 3
    Apr 2015
    25
    Yes I know, I tried using the conversion function but it didn't work so I used the long conversion.
    I don't have a specific criteria, It's just that after I use a test bench I don't get the correct answer.
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,203
    100
    But why? We need to see the complete entity and testbench to understand the reason.
    Full Member level 6
    Points: 3,477, Level: 13
    vipinlal's Avatar
    Mar 2010
    India
    354
    3,477
    13
    you are looking for a BCD to binary converter. Try this code:
    http://vhdlguru.blogspot.in/2015/04/...onversion.html
    If we admit that human life can be ruled by reason, then all possibility of life is destroyed.
    Points: 31,597, Level: 43
    ads-ee's Avatar
    Sep 2013
    USA
    7,307
    31,597
    43
    The only issue I see with the OP's code is the range of output1 should be restricted to 0,1, or 2 as the range of the result for output11 can not be outside the range of 0 to 255. Perhaps the range restrictions are the root of the problem.
  7. #7
    1st Helpful Member
    Jan 2008
    Bochum, Germany
    45,441
    260,203
    100
    I don't think so. In synthesis, casting an integer to unsigned with insufficient length would just cause a wrap around respectively discarding of the upper two bits, e.g. 256 is output as zero.
    A simulator stops with an error when the overflow occurs.
