Jane1
Newbie level 6
I need to read/write NAND flash chips( only from time to time as a hobbyist) . I was thinking about a development board, where I would replace NAND flash chip with a SMD TSOP48 socket( yes the NAND chips I work with are for this socket only).
I will insert a NAND into this socket and will read or write into it via JTAG
If the original NAND have the same size as the NAND chip I am programming, it should work. But what If I need to program( read or write) a NAND with the different size than the original NAND ? Is it possible to set the size of NAND chip on a development board? Or how expensive programmers solve programming of different sizes of flash chips?
Thank you for explanation and your oppinion
