Results 1 to 8 of 8
    Full Member level 5
    Points: 1,987, Level: 10
    Qaisar Azeemi's Avatar
    Feb 2011
    Peshawar, Pakistan, Pakistan
    315
    1,987
    10
    Proteus ISIS suddenly Crashes on Simulation
    I am using Proteus8.1 sp1 on my windows 7. I also checked it on windows 8 but on both It Suddenly Crashes after few mints of simulation.
    To solve the Problem I have Completely Uninstalled it along with its all traces using revo uninstaller and regedit from my system and reinstalled it twice but problem still exists.
    Need your Help and Guidance.
    Thank you
    Qaisar
    Adjustment with right people is always better than argument with wrong people
    and Meaningful silence is always better than meaningless words.....
    "For an optimist the glass is half full, for a pessimist it's half empty, and for an engineer is twice bigger than necessary." :-)
    Junior Member level 1
    Points: 277, Level: 3
    Jan 2014
    15
    277
    Re: Proteus ISIS suddenly Crashes on Simulation
    Do you run it as administrator?
    Points: 10,130, Level: 24
    ALERTLINKS's Avatar
    Dec 2003
    Pakistan
    1,259
    10,130
    24
    Proteus8.1 sp1 crashes many time depending on components used. Proteus 8.0 is stable. Use it instead.
    I know. I know. And once more - I don't know.
    I am too old and would not have enough knowledge to judge, and only have made some remarks in order not to be called ignorant.
    Full Member level 5
    Feb 2011
    315
    1,987
    10
    Yes i am using it as administrator.
    Thanks Alertlinks, i am going to use proteus 8.0 and and let you know the result then.
    thanks again :)
    Full Member level 5
    Feb 2011
    315
    1,987
    10
    pds.exe has stopped working ...
    the schematic file that i've made in proteus 8.1 is now not working on proteus 8.0, and giving the error pds.exe has stopped working. :(
    kindly Help
    ALERTLINKS's Avatar
    Dec 2003
    Pakistan
    1,259
    10,130
    24
    I think, it is not backwards version compatible, you have to redraw.
  7. #7
    Full Member level 5
    Feb 2011
    315
    1,987
    10
    I have Redrawn the circuit in Proteus 8.0 and start simulation but Unfortunately it is also crashing after only a minute of simulation :( ................. :( .........
  8. #8
    Jan 2014
    15
    277
    Last tim i had a crashing problem with ISIS was my code in MCU.
    Do you simulate MCU or what?
