volker@muehlhaus
Advanced Member level 6
https://muehlhaus.com/support/mwo-appnotes/awr_mwo_antenna_simulation
This application note describes the design and simulation of simple PCB antennas for 2.4GHz and 5.6GHz.
The first example shows a 2.45GHz single band antenna.
The second example then shows a dual band version for 2.4GHz and 5.6GHz.
Finally, the sensitivity to PCB material tolerances is investigated.
