The question about Opposite-Edge Capture Center-Aligned Input in Altera AN433
LAORUAN
Newbie level 5
This image comes from Altera AN433.
As we can see, AN433 requires to constraint the Opposite-Edge Capture Center-Aligned Input with multicycle and false path exception. However, in my opinion, we just have to constraint that with false path exception which would remove the analysis of same-edge data transfer labelled as 1 and 2 in the image.
I practice the Opposite-Edge Capture Center-Aligned DDR input in Quartus II. I only contrait the false path, and then, I get the right result.
