LCD code works only in debugging mode not out of debugging.
anand003
Junior Member level 2
bangalore
I need some help to fix code issues on LCD 16X2 which I have implemented for MSP430F5132 controller.(see the attachment ) . And it is seem to be working only while debugging, i.e it is displaying characters while debugging not after coming out from debugging.
I guess the issue is related to either the clock or with delays in the program. Anyways attaching the code with this query ,this will give more light to understand the problem.
Note: I as mentioned earlier, the code works in debugging mode.
A little help to solve the issue would be appreciated.
Thanks in advance.
Anand.
  • version2.rar
when running in debugging mode the system tends to run much slower than when not debugging so I would guess you are sending data to the LCD too fast
LCDs can be very slow devices so one usually has to put delays between writing data, e.g. this is writing a nibble on a PIC24FJ256GB110 running at 32MHz
// Write a nibble to the LCD
// may have to adjust delays to suit the processor and clock
void lcdNibble(int n)
    int lcd=LCDdata;
	__delay_us(800);
  	LCDdata = (lcd&0xfff0) | ((n & 0x0f));			// send out lower Nibble
  	Nop();					// Wait E Pulse width time (min 230ns)
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
  LCDstatus.E=1;					// take clock E high
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
	Nop();
    LCDstatus.E=0;
 	__delay_us(800);
// Write a Control Command to the LCD
// This is written as two nibbles
void lcdCmd(int c)
 	LCDstatus.RS=0;			        // Take RS pin low for command
	lcdNibble(c >>4);		        // Makeup Upper Nibble
	lcdNibble(c);			        // Makeup Lower Nibble
I uisually make the delays long, e.g. 5mSecs then reduce them until I get a stable working version
hello horace1,
Thanks for replying
Even though I tried playing with delays, I didn't tried delaying enable signal will try that and update
I have tried with nop function and delays there seems to be no success. I am attaching picture to understand the problem better the pic 1 while working in debugging ( even in continuous run ) but fails to run in normal condition without emulator connected. Pic2
I think u should revise the timing requirement(Bus Timing Characteristics) in pages 49 & 52
here https://www.sparkfun.com/datasheets/LCD/HD44780.pdf & compare them to the timing used in your code.
Also u should revise timing needed during initialization in pages 45 & 46
(also LCD intial. here can be more explanatory here
**broken link removed**)
1. It works in debug mode, which shows that the data timing and bus timing is correct!!.( further to confirm will cross verify).
2.If the debug mode and the normal mode works same clock speed ..should work in both conditions....!!!??
