Need help to converting a mikro code to MPlab with Compilr C30
ings
Member level 4
how to convert mikroc code to a mplab c30 to display in lcd
Hello i would like to convert a mikro code to MPlab with Compilr C30 that display a parameter in a LCD with the pic24f
This is a project in MikroC that works with pic18f.
please help me
thanks in advace
  • PIC18F452 LCD.rar
Re: how to convert mikroc code to a mplab c30 to display in lcd
Which MCU are you using and what clock are you using ? Post your circuit. Mention the connections between MCU and LCD.
i would lke to use pic24fj256ga110 and LCD : LM044L and the connections is lke this figure
My pameter of the clock are
#define Fosc		8000000
#define Fcy			(Fosc/2)
#define Fs   		4000
#define SAMPPRD		(Fcy/Fs)-1
// JTAG/Code Protect/Write Protect/Clip-on Emulation mode
//Watchdog Timer/ICD pins select
_CONFIG1(JTAGEN_OFF & GCP_OFF & GWRP_OFF & COE_OFF & FWDTEN_OFF & ICS_PGx2)
// Disable CLK switch and CLK monitor, OSCO or Fosc/2, HS oscillator,
// Primary oscillator
_CONFIG2(FCKSM_CSDCMD & OSCIOFNC_OFF & POSCMOD_XT & FNOSC_PRI)
thanks in advance
