+ Post New Thread
Results 1 to 7 of 7
  1. #1
    Junior Member level 1
    Points: 1,709, Level: 9
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    17
    Points
    1,709
    Level
    9
    ADC integrated in an ASIC
    Hi guys,
    I was wondering if you know wich types of Analog to digital converter can be integrated into an ASIC? Do u know any document I can refer to? Or any example?
    Thanks so much.
    Posted via Topify on Android
    •   AltAdvertisement
  2. #2
    Advanced Member level 3
    Points: 5,768, Level: 18
    Dominik Przyborowski's Avatar
    Join Date
    Jun 2013
    Norway
    Posts
    755
    Points
    5,768
    Level
    18
    Re: ADC integrated in an ASIC
    Everyone. About 100 designs per year is published in each journal -- pipeline, SAR, flash, etc.
  3. #3
    Advanced Member level 5
    Points: 39,705, Level: 48
    Join Date
    Mar 2008
    USA
    Posts
    6,413
    Points
    39,705
    Level
    48
    Some of this depends on the "ASIC" target foundry flow. A
    mostly-digital sigma-delta converter is popular (esp. in audio
    ranges and lower) because almost any cheapo digital flow
    can support it. Whereas others are needful of high quality
    matching and linearity in resistors or capacitors, which may
    not be available or well enough controlled / modeled to hit
    the goal.
    Many things "can" be done, but fewer will be satisfactory in
    cost, effort or outcome. Bounding the problem improves the
    solution.
    •   AltAdvertisement
  4. #4
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    17
    Points
    1,709
    Level
    9
    Ok so basically I need to have a look to the literature for ADC solution.
    Do you know of any way to compare an Asic chip with and wihout an integrated ADC? Is there any tool I can use?
  5. #5
    Join Date
    Mar 2008
    USA
    Posts
    6,413
    Points
    39,705
    Level
    48
    If you are just looking to -have- an ADC, rather than design
    one (or even if you think designing one is the most economical
    path forward) you ought to begin with your target foundry
    and its list of IP provider partners. If you're going with any
    major player, at any node below 250nm, you ought to find
    a buttload of hard-IP ADCs offered (well, maybe some are
    still in development, for 40nm and under). And I contend
    that unless you've done a number of ADC designs and layouts
    before, the extent of art involved says "buy" rather than
    "invent" unless it's all about the process of invention and
    not a timely product rollout.
  6. #6
    Achievements:
    7 years registered
    Join Date
    Apr 2010
    Posts
    17
    Points
    1,709
    Level
    9
    Maybe i didn't explain very well my question. I'm interested ro know if there is any tool which permit to calculate the piece price of an ASIC having some features with and without an integrated ADC. Are you aware about it?
    •   AltAdvertisement
  7. #7
    Join Date
    Mar 2008
    USA
    Posts
    6,413
    Points
    39,705
    Level
    48
    Can't help you there. As one of my VP-GMs was fond of saying,
    "cost and price are unrelated". At least, a business that is in
    control of its pricing will price by value-to-the-customer, not
    cost-to-fabricate.
    If you're not in control of your pricing then life is not good.
    It's how much of the industry operates, but it's a dismal
    existence for everyone but the highly incentivized guys
    at the top. The rest are just cost-components to be beaten
    down along with the die size.
    Philosophy aside, you could attack this by bottom-up cost
    for dice of two different areas and two different complexities
    of test program / test time and two different yield numbers,
    assigning some yield detraction to the fancier, fussier analog
    content and parameters (and perhaps the cost ratio of two
    flows, one base digital and one including "mixed signal features"
    where two such can be found together. You might be able to
    find examples of function IP blocks that declare involved-area
    and yieldability (or maybe not, until you convince them you're
    a customer instead of an analyst).
    Canned tools, though, I got nuthin'.
