Results 1 to 8 of 8
    Newbie level 6
    Points: 283, Level: 3
    Sep 2014
    13
    283
    Turning two bits into one two-bit binary number
    Hello everyone. I need help on a homework assignment:
    Write a C program that treats A1A0, A3A2, and A5A4 as three 2-bit unsigned binary
    number. The program should output the sum of those three numbers onto B.
    I need help with the 'treat A1A0... 2-bit unsigned binary number.' I figure I'd have to use the GetBit function but i dont know how to get two bits and make them a one two-bit number.
    Thank you in advance.
    Points: 12,735, Level: 27
    Nov 2008
    Norwich, UK
    2,123
    12,735
    27
    Re: Turning two bits into one two-bit binary number
    I assume you are reading the bits of PORTA
    you can extract the bits so
    int A10=PORTA & 3;
    int A32 = (PORTA >> 2) & 3
    etc
    is that what you want to do?
    Newbie level 6
    Sep 2014
    13
    283
    I dont know what PORTA is, but I'm using RIMS software, which is a microcontroller simulator. This is what it looks like.
    Nov 2008
    Norwich, UK
    2,123
    12,735
    27
    if A1 and A0 are one bit variables to create a two bit variable you shift A1 one biit left and add A0 to it
    A1A0=(A1<<1) + A0;
    Newbie level 1
    Points: 14, Level: 1
    Jan 2015
    14
    what if id want to set B to the reverse of A, such at B7 = A0, B6 = A1; while using a for loop. This is using the same program as above. Any help is appreciated.
    Points: 7,828, Level: 21
    Jan 2015
    1,097
    7,828
    21
    If 'A' and 'B' are arrays (i.e. "B7" really means "B[7]" in c-like syntax) then you can use an index into the arrays within the for-loop.
    If they are separate variables, but you can define them in a structure (which gives you come control over their relative addresses) then create a pointer to the start or end of the structures and increment/decrement the pointers within the for-loop.
    Susan
  7. #7
    Points: 81,438, Level: 69
    2nd Helpful Member
    betwixt's Avatar
    Jul 2009
    Aberdyfi, West Wales, UK
    13,351
    81,438
    69
    Looking at the simulator it appears 'A' is an 8-bit input port and 'B' is an 8-bit output port in a hypothetical processor. The question is one of adding the 'A' bit pairs together and puting the result on 'B' so it boils down to shifting them to align with the LSB, adding them to a variable (it doesn't say whether 'B' can be used as an accumulator) then outputting the result on 'B'.
    BiscuitDuke - it's your work but try this workflow:
    C = A & 0b00000011;
    C += (A & 0b00001100) >> 2;
    C += (A & 0b00110000) >> 4;
    B = C;
    I show the numbers in binary so you can see how the '&' operator can be used to isolate the '11' bits from the rest of the value in 'A' so only the ones you are interested remain and the other bits are set to zero.
    The '+=' is short hand for "the value on the right is added to the value on the left"
    The '>>' operator shifts the whole 'A' value by the number of places in the number. In my example you can see it is used to move the bit pairs to the rightmost (LSB) places so all three pairs are aligned with each other before adding them.
  8. #8
    Jan 2015
    1,097
    7,828
    21
    I'm sorry, my previous reply was addressed to Micro_Tech90 but I had not realised that he had hijacked the thread. So to Micro_tech90 - use Google as bit reversal in the way you are talking about is a very common operation. Look for bit twiddling and you should find a whole stack of techniques and code.
    Susan
