ahgu
Full Member level 3
I have a circuit that require 15Vdc, I used LMR62014 (1.6MHz) initially. The circuit run okay, except the noise a little high.
so I put a LT1761 after LMR62014. Changed the LMR62014 Vout to 16vdc, and LT1761-byp to 15v.
I notice the LT1761 Voutput has ripple triangular voltage, several hundred hertz, magnitude about several hundred millivolts.
I thought it is the LDO issue, changed the bypass cap to tantalum, added 0.5ohm in series with the output, but nothing helped.
Anyway, I need 15vdc with 10mA of low noise voltage supply, I don't have to use the above switcher, anyone please recommend.
thank you
ahgu
thank you
ahgu
