Interview questions for embedded systems programmer
bayou1221
Newbie level 2
firmware interview questions
Hello all,
Can anybody tell me what questions can be asked for the position of a Embedded Systems Programmer.
They are looking for C and embedded firmware development, serial and ethernet communications and protocol conversion.
I will really appreciate any help I can get.
Thanks,
BA
embedded system interview questions
Hello BA
Here is a question i was asked long time ago :
In an embedded system you have a software who run a function "test(char Data)" with a sigle static 8 bit register.
void test(char Data)
static char Reg;
char temp
/* your code start here use temp for data process */
/*your code end here */
Display(temp);
the main software call that function "test()" who calls a display routine , each time the function called an 8 bit data is trnsferd to the function
Your task is to write the contents of the function to show on the dispaly the mean of the last 10 function call's.
Good luck
Bobi
embedded systems interview questions
Let's call this is Q1. it wouls be easy to refer with Question number when this topic goes lengthy with lots of such questions.
i have one more question.
Q2) what is volatile keyword, and its significance?
i was asked in an interview. this is also related to embedded systems only.
I still not sure what is the significance of volatile.
regards
srinivas
embedded firmware interview questions
vasureddym said:
... I still not sure what is the significance of volatile. ...
read this:
Mik
In embedded systems without an OS, volatile is used when declaring variables that can be altered out side of their scope. ie global variables that are altered by isr's and/or hardware events.
embedded software interview questions
bobcat1 said:
Hello BA
static char Reg;
char temp
Display(temp);
Good luck
Bobi
how would you solve it?
interview questions on embedded systems
Hello Banh
The answer is simple !
all you have to do is to mean the value of reg with vlau of data and send it to display e.g.
static char Reg;
char temp ;
temp = ((Reg + Data)/2)
reg = temp;
Display(temp);
All the best
Bobi
hey,
it should not be the mean of the last 10 values?
firmware development interview questions
Hello Banh
Yes,
but this is the closest and simplest way to do it , i think ....
All the best
Bobi
embedded and firmware interview questions
I would prefer asking electronics basic stuff, like power supply circuit design, interfacing techniques, and other kind of basic knowledge about electronics system.
Btw, Bayu. i sent my interview question samples to you by email already. Have you read them :D?
what has embedded software to do with power supply design?
It's not that someone cannot design a power supply that he cannot write/design good embedded software.
Programming skills, insight in processor architectures, perhaps OS architectures, ... might be beter to look for.
Antharax
embedded system questions
bobcat1 said:
Hello Banh
static char Reg;
char temp ;
reg = temp;
Display(temp);
All the best
Bobi
Are you sure that (written for 3 values):
((data1 + data2)/2 + data3)/2 equal to (data1 + data2 + data3)/3 ??
embedded software engineer interview questions
Yes
Because the function receive only 1 parameter and can't remember more the 1 parametr when exit
All the best
Bobi
interview question firmware
bobcat1 said:
Yes
All the best
Bobi
May be we can do :
static char Reg;
char temp ;
Reg += Data/10;
temp = Data;
Display(temp);
but we do not know how many times the function will be called - there is no additional static memory to count calls ...
embedded software interview question collection
Dear Artem
This answer is the closest way to do a mean of 10 since you can't count how many time the function have bean called
Some time in tests you don't have to give the exact answer.
All the best
Bobi
