[ARM] STM32, FatFS and NandFlash ?
bianchi77
California
Guys,
Are there any reference for using FATFs with STM32 and NANDFlash ?
thanks
There are a lot of resources for FATFs. Have a look at the CHAN FATFs library. For nand Flash you have to read the datasheet for the specific microcontroller; have a look at Flexible static memory controller(FSMC) and FMC in datasheet. .
cheers
cheers
Even I am looking out for FAT file system for lpc2148,will chan's fatfs library work?
You have to read the Chan's FATFs page.the FatFs library definitely works but It depends on how RAM is available on LPC2148.
cheers
Reactions: shruv
    shruv
cheers
Will go through that. lpc2148 has 40kb of RAM.
which chip do you use ? i have some example with STM32f407,it have fatfs and nandflash ,but if you often write and read,it wile have a little bug.so you must buy a good system.
I used K9F, yes please, you can upload your example, thank you
oK,this is the code,but the note is chinese.if you some question,we can chat with you..
  • V5-107b_FatFS文件系统例程(NAND Flash)(V.rar
