dellpe
I need to be able to have PC access to 2 different routers either their web gui interface or access to the WAN each router provides. Currently, both routers are plugged into the internet modem. I always have 1 ethernet cable from my PC connected to one of the routers. When I need to switch from one network to another, I unplug the cable from that one router and plug it into the other. I also have at my disposal a huawei S5700-28C-EI switch but currently it is not used in this particular setup.
Is it possible for me to connect my PC along with both routers into this switch and then run 2 ethernet cables from this switch to each port on my internet modem? I am trying to figure out a way I can connect everything up to my PC at once and easily, without disconnecting cables, switch from one wan/router to another. Is this possible using this switch and if so, how do I switch from one router to the other while remain at my PC?
