Hello guys, I want to read massage from sim900 modem..
whenever I use AT+CMGF=x command modem is replying with OK instead of massage.
what should I have to do?
hahah.. i have sent more than dozen massages to that sim..even i used AT+CPMS="SM" to select sim memory.. tried other simcard.. but no effect.. it again responded OK only..earlier my gsm modem was working perfectly .. do you have any other idea to solve this problem? thanks for previous replies.
SORRY if I disappointed you.. I did not intended that..
and I tried both ways.. sending message before powering on modem and then check using hyper_terminal and also as u mentioned above.. but result was same..
is there any command to auto delete massage?
my modem is showing received massage only when it is connected to hyper-terminal...
hey.. i just inserted that same sim card into mobile.. but there was no any message stored in the message memory..
i think my messages are being stored on the memory of sim900(if it has its own)..or sim900 is deleting my messages..
what do you thing?
