[SOLVED] 8051 blinking led code
sherryliu
Hi guys,i want to modified code to show blink led difference,how to optimized the code.when i click one show one way and click again show other way.
#include <reg51.h>
#include<intrins.h>
unsigned char tmod=0;
unsigned char i ,j,tmp;
void delay_1ms(void)
unsigned int i;
for (i=1;i<(unsigned int)(1144-2);i++);
void delay_ms(unsigned int n)
unsigned int i=0;
while(i<n)
delay_1ms();
i++;
void main(void)
ET0=1;
ET1=1;
EX0=1;
EX1=1;
EA=1;
while(1)
P0=0x00;
void int0(void) interrupt 0
switch(tmod)
case 0:
tmp=0x01;
for(j=8; j>0; j--)
P0=~tmp;
delay_ms(50);
tmp =tmp<<1;
break;
case 1:
tmp=0x80;
for(j=8; j>0; j--)
P0=~tmp;
delay_ms(50);
tmp = tmp>>1;
break;
case 2:
break;
tmod+=1;
if(tmod==2)tmod=0;
Hi jayanth
I used interrupt 0 to control blinking led,i want click it show one style,and click it again show other style.
mikroC Code for P1. Not tested. Test in hardware.
Code C - [expand]
8
9
10
11
12
13
14
15
16
17
18
19
20
21
22
23
24
25
26
27
28
29
30
31
32
33
34
35
36
37
unsigned char togglemode = 0, i = 0;
void Interrupt() {
     if(IE0_bit)
     togglemode = ~togglemode;
     IE0_bit = 0;
void main() {
     P1 = 0x00;
     P3.F2 = 1;
     EX0_bit = 1;
     IE0_bit = 1;
     IT0_bit = 1;
     EA_bit = 1;
     while(1){
             if(togglemode){
                   P1 = 0x01;
                   for(i = 0; i < 8; i++) {
                          P1 <<= 1;
                          Delay_ms(500);
             else if(!togglemode){
                   P1 = 0x80;
                          P1 >>= 1;
                          Delay_ms(500);
I have modified code ,can do it.thanks!!
  • blinking led.rar
