arbj2
Full Member level 3
I would like to connect a MAX 232 IC to the beaglebone black, I will use the UART4 serial port of the BeagleBone.
As the bone runs on 3.0 V and the MAX 232 on +5V I will not be able to use the chip directly.
So is it possible to run the MAX 232 on 3.0 V instead of 5V, the datasheet mentions a VCC range of -0.3V to +6.0V, so I think this should work, but the recommended voltages are 4.5 to 5.5V.
Is it OK to run the MAX 232 at 3.0V instead of +5.0V ??
thanks
a
thanks
a
