Results 1 to 5 of 5
    Points: 1,170, Level: 7
    Mar 2010
    india (U.P.)
    51
    1,170
    7
    accuracy test for LM3915 led bar graph driver
    I am using LM3915 for a application of mine i.e audio level detection.
    I am able to run the ic well but my doubt is that the data sheet says that it acts as per 3dB/Step.
    How i decode this is dt when we say 3dB change that means audio power has doubled i.e. in formula 10log(base10)(P2/P1), the P2 = 2*P1
    Since, P(Power) = V(square)/R it implies that 10log(base10)(P2/P1) = 20log(base10)(V2/V1)
    M i right till here?
    if yes thn in proteus as well as practical how come my following readings relate to 3dB/step change?
    1st led at .06V
    2nd led at .08V
    3rd led at .12V
    4th led at .16V
    5th led at .22V
    6th led at .32V
    7th led at .44V
    8th led at .63V
    9th led at .88V
    in place of leds actually i have pulled up every pin with a 10k resistance and monitoring the pin by help of mulitmeter. when no audio the pin remains at 5v and becomes low between mV when some audio exists depending on audio level
    in proteus the 10K R11 is replaced with value between 100R to 1k for the same result else it doesnt work in protues but practically is working
    Points: 11,015, Level: 25
    Apr 2012
    1,981
    11,015
    25
    Re: accuracy test for LM3915 led bar graph driver
    Quote Originally Posted by sachinkp21587 View Post
    Yes, that's right.
    So for a 3dB increase:
    P2/P1 = 1.9953 (almost = 2)
    V2/V1 = 1.4125 (almost = sqrt(2))
    It looks about right. Here I've added the dB increments between each LED:
    1st led at .06V
    2.50dB
    2nd led at .08V
    3.52dB
    3rd led at .12V
    2.50dB
    4th led at .16V
    2.77dB
    5th led at .22V
    3.25dB
    6th led at .32V
    2.77dB
    7th led at .44V
    3.12dB
    8th led at .63V
    2.90dB
    9th led at .88V
    Mar 2010
    india (U.P.)
    51
    1,170
    7
    2.50dB is approximated as 3dB ? Is int it over approximation? i mean .50db error
    added i would like to know that is there any way that i can only switch of or on the led in place of toggling the brightness
    also please let me know the difference between LM3916 and LM3915.
    Thanks for your kind attention
    Apr 2012
    1,981
    11,015
    25
    The manufacturer doesn't claim great accuracy. The datasheet says:
    minimum: 2dB
    maximum: 4dB
    typical: 3dB
    so it's within spec.
    LM3916 is similar, but the step sizes are different. Check the datasheet or Google for details.
    Mar 2010
    india (U.P.)
    51
    1,170
    7
    added i would like to know that is there any way that i can only switch off or on the led in place of toggling the brightness
    Please guide in this regard also
