Results 1 to 4 of 4
    Member level 5
    Points: 745, Level: 5
    Aug 2012
    82
    745
    thermal resistance _ junction to ambient
    Could you help me please with the formula of calculating the thermal resistance for junction to ambient?
    I have to do some calculations for power LEDs, and unfortunately the datasheet provides me just the thermal resistance junction to solder point.
    Thank you in advance.
    Points: 51,806, Level: 55
    erikl's Avatar
    Sep 2008
    Germany
    8,085
    51,806
    55
    Re: thermal resistance _ junction to ambient
    Both thermal resistances are in series, i.e. have to be added.
    Points: 14,794, Level: 29
    schmitt trigger's Avatar
    Apr 2013
    2,461
    14,794
    29
    Rja = Rjs + Rsh + Rha
    Rja: junction to ambient, total resistance
    Rjs: junction to solder point, the value that you already know
    Rsh: solder point to heatsink, estimated from typical values
    Rha: heatsink to ambient, you have to select a heatsink to meet your requirements
    those requirements are:
    Tj(max) > (Pled * Rja) + Tamb(max)
    Points: 19,003, Level: 33
    crutschow's Avatar
    Feb 2012
    L.A. USA Zulu -8
    3,665
    19,003
    33
    You select a heatsink as determined from the power dissipated by the LED, the highest ambient temperature, and the maximum LED junction temperature (Tj) you want (should be below the maximum allowed for good reliability). From this, and the thermal impedance calculation given by schmitt trigger above, you determine the thermal resistance to air you need and select the appropriate heat sink.
    Zapper
    Curmudgeon Elektroniker
