Verilog input seeding - Help
kobay000
Newbie level 1
Hi guys, i am new at Verilog. I generated a working Verilog file using Matlab HDL Generation Tool. I tested it with 16 binary bits using assign parameters and it worked for this values. But i need an input [1x1000000] random binary matrix. The following code must use this matrix with 16 bits block. How can produce a random [1x1000000] binary matrix and use this matrix dividing it 16 bits blocks (at total 1000000/16=62500 blocks) ? I searched at the internet and found a parameter named "initial" and some says i need a testbench file. Also I must show bit changes on quartus ii with waveform. Here is my code. Thanks in advance.
`timescale 1 ns / 1 ns
module serpistirici
           clk,
           reset,
           clk_enable,
           veri_0,
           veri_1,
           veri_2,
           veri_3,
           veri_4,
           veri_5,
           veri_6,
           veri_7,
           veri_8,
           veri_9,
           veri_10,
           veri_11,
           veri_12,
           veri_13,
           veri_14,
           veri_15,
           ce_out,
           serpistirilmis_veri_0,
           serpistirilmis_veri_1,
           serpistirilmis_veri_2,
           serpistirilmis_veri_3,
           serpistirilmis_veri_4,
           serpistirilmis_veri_5,
           serpistirilmis_veri_6,
           serpistirilmis_veri_7,
           serpistirilmis_veri_8,
           serpistirilmis_veri_9,
           serpistirilmis_veri_10,
           serpistirilmis_veri_11,
           serpistirilmis_veri_12,
           serpistirilmis_veri_13,
           serpistirilmis_veri_14,
           serpistirilmis_veri_15
  input   clk;
  input   reset;
  input   clk_enable;
  input   signed [15:0] veri_0;  // int16
  input   signed [15:0] veri_1;  // int16
  input   signed [15:0] veri_2;  // int16
  input   signed [15:0] veri_3;  // int16
  input   signed [15:0] veri_4;  // int16
  input   signed [15:0] veri_5;  // int16
  input   signed [15:0] veri_6;  // int16
  input   signed [15:0] veri_7;  // int16
  input   signed [15:0] veri_8;  // int16
  input   signed [15:0] veri_9;  // int16
  input   signed [15:0] veri_10;  // int16
  input   signed [15:0] veri_11;  // int16
  input   signed [15:0] veri_12;  // int16
  input   signed [15:0] veri_13;  // int16
  input   signed [15:0] veri_14;  // int16
  input   signed [15:0] veri_15;  // int16
  output  ce_out;
  output  signed [15:0] serpistirilmis_veri_0;  // int16
  output  signed [15:0] serpistirilmis_veri_1;  // int16
  output  signed [15:0] serpistirilmis_veri_2;  // int16
  output  signed [15:0] serpistirilmis_veri_3;  // int16
  output  signed [15:0] serpistirilmis_veri_4;  // int16
  output  signed [15:0] serpistirilmis_veri_5;  // int16
  output  signed [15:0] serpistirilmis_veri_6;  // int16
  output  signed [15:0] serpistirilmis_veri_7;  // int16
  output  signed [15:0] serpistirilmis_veri_8;  // int16
  output  signed [15:0] serpistirilmis_veri_9;  // int16
  output  signed [15:0] serpistirilmis_veri_10;  // int16
  output  signed [15:0] serpistirilmis_veri_11;  // int16
  output  signed [15:0] serpistirilmis_veri_12;  // int16
  output  signed [15:0] serpistirilmis_veri_13;  // int16
  output  signed [15:0] serpistirilmis_veri_14;  // int16
  output  signed [15:0] serpistirilmis_veri_15;  // int16
  wire enb;
  wire signed [15:0] veri [0:15];  // int16 [16]
  reg signed [15:0] serpistirilmis_veri [0:15];  // int16 [16]
  reg signed [15:0] serpistirici_A_1 [0:15];  // int16 [16]
  reg signed [31:0] serpistirici_k_1;  // int32
  reg signed [31:0] serpistirici_t_0_1;  // int32
  reg signed [31:0] serpistirici_t_1_1;  // int32
  reg signed [31:0] serpistirici_t_2_1;  // int32
  reg signed [31:0] serpistirici_t_3_1;  // int32
  reg signed [63:0] serpistirici_cast_1 [0:3];  // sfix64 [4]
  reg signed [63:0] serpistirici_add_cast_2 [0:3];  // sfix64 [4]
  reg signed [63:0] serpistirici_add_cast_0_1 [0:3];  // sfix64 [4]
  reg signed [63:0] serpistirici_add_cast_1_1 [0:3];  // sfix64 [4]
  assign veri[0] = veri_0;
  assign veri[1] = veri_1;
  assign veri[2] = veri_2;
  assign veri[3] = veri_3;
  assign veri[4] = veri_4;
  assign veri[5] = veri_5;
  assign veri[6] = veri_6;
  assign veri[7] = veri_7;
  assign veri[8] = veri_8;
  assign veri[9] = veri_9;
  assign veri[10] = veri_10;
  assign veri[11] = veri_11;
  assign veri[12] = veri_12;
  assign veri[13] = veri_13;
  assign veri[14] = veri_14;
  assign veri[15] = veri_15;
  assign enb = clk_enable;
  always @* begin
    //spssa
    //Oluþturulacak ara matrisin satýr sayýsý
    //Gönderilecek verinin 4 ün katý olup olmadýðýný kontrol etme, eðer deðilse
    //eksik bit sayýsý kadar boþluðu temsil eden sýfýr deðerini girme
    //Ara matrisi oluþturma
    for(serpistirici_k_1 = 0; serpistirici_k_1 <= 15; serpistirici_k_1 = serpistirici_k_1 + 1) begin
      serpistirici_A_1[serpistirici_k_1] = veri[serpistirici_k_1];
    end
    //Oluþturulan ara matris yardýmýyla serpiþtirilmiþ veriyi bulma
    for(serpistirici_t_0_1 = 0; serpistirici_t_0_1 <= 3; serpistirici_t_0_1 = serpistirici_t_0_1 + 1) begin
      serpistirici_cast_1[serpistirici_t_0_1] = {{30{serpistirici_t_0_1[31]}}, {serpistirici_t_0_1, 2'b00}};
      serpistirilmis_veri[serpistirici_t_0_1] = serpistirici_A_1[serpistirici_cast_1[serpistirici_t_0_1]];
    end
    for(serpistirici_t_1_1 = 0; serpistirici_t_1_1 <= 3; serpistirici_t_1_1 = serpistirici_t_1_1 + 1) begin
      serpistirici_add_cast_2[serpistirici_t_1_1] = {{30{serpistirici_t_1_1[31]}}, {serpistirici_t_1_1, 2'b00}};
      serpistirilmis_veri[serpistirici_t_1_1 + 4] = serpistirici_A_1[1 + serpistirici_add_cast_2[serpistirici_t_1_1]];
    end
    for(serpistirici_t_2_1 = 0; serpistirici_t_2_1 <= 3; serpistirici_t_2_1 = serpistirici_t_2_1 + 1) begin
      serpistirici_add_cast_0_1[serpistirici_t_2_1] = {{30{serpistirici_t_2_1[31]}}, {serpistirici_t_2_1, 2'b00}};
      serpistirilmis_veri[serpistirici_t_2_1 + 8] = serpistirici_A_1[2 + serpistirici_add_cast_0_1[serpistirici_t_2_1]];
    end
    for(serpistirici_t_3_1 = 0; serpistirici_t_3_1 <= 3; serpistirici_t_3_1 = serpistirici_t_3_1 + 1) begin
      serpistirici_add_cast_1_1[serpistirici_t_3_1] = {{30{serpistirici_t_3_1[31]}}, {serpistirici_t_3_1, 2'b00}};
      serpistirilmis_veri[serpistirici_t_3_1 + 12] = serpistirici_A_1[3 + serpistirici_add_cast_1_1[serpistirici_t_3_1]];
    end
  end
  assign serpistirilmis_veri_0 = serpistirilmis_veri[0];
  assign serpistirilmis_veri_1 = serpistirilmis_veri[1];
  assign serpistirilmis_veri_2 = serpistirilmis_veri[2];
  assign serpistirilmis_veri_3 = serpistirilmis_veri[3];
  assign serpistirilmis_veri_4 = serpistirilmis_veri[4];
  assign serpistirilmis_veri_5 = serpistirilmis_veri[5];
  assign serpistirilmis_veri_6 = serpistirilmis_veri[6];
  assign serpistirilmis_veri_7 = serpistirilmis_veri[7];
  assign serpistirilmis_veri_8 = serpistirilmis_veri[8];
  assign serpistirilmis_veri_9 = serpistirilmis_veri[9];
  assign serpistirilmis_veri_10 = serpistirilmis_veri[10];
  assign serpistirilmis_veri_11 = serpistirilmis_veri[11];
  assign serpistirilmis_veri_12 = serpistirilmis_veri[12];
  assign serpistirilmis_veri_13 = serpistirilmis_veri[13];
  assign serpistirilmis_veri_14 = serpistirilmis_veri[14];
  assign serpistirilmis_veri_15 = serpistirilmis_veri[15];
  assign ce_out = clk_enable;
endmodule
