Error (10500): VHDL syntax error at near text "enable"; expectexpecting "begin", or
wan khusairi
Newbie level 3
Kuala Terengganu Malaysia
hello im still new in thie VHDL and have very liitle bit programming skill. i have created a program that read movement from a PIr sensor and i would like the output of is to be maintained in minutes..here i attaced my program but it seem that error Error (10500): VHDL syntax error at AcounterGpio2.vhd(29) near text "enable"; expecting "begin", or a declaration statement existed and i dont know how to repair it. how can i eliminated the error. herewith is the code that i developed. really need your help for this program..
how does i program my counter so that the output will be maintained in minutes..tq in advance
library ieee;
use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_unsigned.all;
entity AcounterGpio2 is
port( PIRin : in std_logic;
clk : in std_logic;
reset : in std_logic;
PIRout : out std_logic;
q : out std_logic);
end AcounterGpio2 ;
architecture bufferwithGpio_arc of AcounterGpio2 is
signal cnt,enable: std_logic;
begin
process(PIRin)
begin
if PIRin = '1' then
PIRout <= PIRin ;
else PIRout <= '0';
end if;
end process;
counter:process (clk)
enable <= PIRout;
begin
if (rising_edge(clk)) then
if reset = '1' then
cnt := 0;-- Reset the counter to 0
elsif enable = '1' then
cnt := cnt + 1;-- Increment the counter if counting is enabled
end if;
end if;
-- Output the current count
end process counter;
q <= cnt;
end bufferwithGpio_arc;
Re: Error (10500): VHDL syntax error at near text "enable"; expectexpecting "begin"
You cannot put signal assignments before the "begin" of a process.
Also - := is for assigning variables, not signals.
There is also no possibility to read from output port in its architecture (PIRout : out std_logic;). You can change it to inout port and do it (highly not recommended) or add another internal signal to handle this.
simple example of how u can handle this
library ieee;
  port (
    CLK	 : in std_logic;
    RESET	 : in std_logic;
end entity AcounterGpio2 ;
  --! your val to be counted
  constant END_VAL : integer :=100;
begin
  counter:process(clk)
  variable cnt : integer :=0;
  begin
    if RISING_EDGE(CLK) then
      if RESET = '1' then
        cnt := END_VAL;-- Reset the counter to END_VAL
      elsif PIRin = '1' then
        cnt := 0;
        PIRout <='1';
      --! start counting to END_VAL
      elsif cnt < END_VAL then
        PIRout <= '1';
      else
        cnt := END_VAL;
        PIRout <='0';
      end if;
    end if;
If u want to maitance output for known time u just have to convert that time to clock ticks i.e: 1 minute when your clock is 1 Mhz req. counter that will count to 10^6, so in my simple code END_VAL shoudl be 1_000_000;
It is ok with VHDL 2008
Never ever do this, unless you're building a tri state bus.
And also want to declare the counter like this, to prevent it creating a 32 bit integer.
  variable cnt : integer range 0 to 2**7-1 :=0;  --only implements 7 bits
There were actually only 2 minor problems in the original code :
the line
enable <= PIRout;
should be moved to after the begin
and either you define cnt as a variable in the process (as suggested before) or you make cnt a signal (like you did), but then all the assignments should be changed to treat cnt as a signal:
cnt <= 0;-- Reset the counter to 0
cnt <= cnt + 1;-- Increment the counter if counting is enabled
Also, I would never ever read back an output port - quite tricky IMHO. I prefer a temporary signal as placeholder for the output value and then assign this to the output port.
making a port inout (i.e. tristate) is ok only if that port is the top level of your system
how can i create a temporary signal as placehold for the output value and then assign it to the output port.. when should i use signal or variable and what is the difference between them.
for axcdd i have try running the program that you have editted and no error was found but when i try start to do pin assignment nothing happen..bye the way i just use 50Mhz clock as the clk and also the switch sw0 as it reset..have i done any mistake on using the clk or the switch as my rest button.
A signal is updated whenever the process that is assigned in suspends (eg hits a wait statement or finishes when it has been triggered by a signal in the senstivity list).
A variable is updated immediatly.
If you dont know the difference, then you should always stick with signal until you understand VHDL better. you're less likely to have problems.
you're defining a temporary signal just the same as any other signal. To show the usage:
entity blabla
   port (
      in_data : in std_logic;
      out_data : out std_logic
end entity blabla;
architecture ...
signal mysignal, another_signal : std_logic;
begin
process (...)
begin
   if ...
      another_signal <= '0';
   elsif rising_edge (..) then
      if mysignal = '1' then
         another_signal <=  ...
      else
      end if;
   end if;
end process;
process ...
begin
   if ..
      mysignal <= '0';
   elsif rising_edge ...
       mysignal <= '1';
   end if;
end process;
out_data <= mysignal;
end architecture ...;
