Altium : Converting 45 Routing bands into Arc Routing
PCB Designers
Member level 3
Karachi, Pakistan
Dear all,
I am a user of Altium Designer Summer 09.
I have routed a board on 45 degree bands. Now, I want to convert these 45 degree bands into Arcs. I have searched, but unable to find a way out.
(In PCAD 200X) there was a tool named as "Mitor". We used it a lot, to do the same; but in Altium, I am searching for a solution)
Looking forward for your comprehensive responses.
Kind Regards,
Maqbool
Press SHIFT + SPACEBAR for arc while routing
Thank you very much Anil,
It helped me a lot.
I found that after running the utility, it is not possible to undo it.
What I am thinking to rewrite a script in VB with some selection/filter (Layer, netclass, bend size) menus for specific operations, in near future.
Hopefully, I will bother you for that also :smile:
Thank you again dear.
Regards,
Maqbool
Run the attached script this will convert the 45 degree track to arcs.
Regards,
Anil
Thank you, but I asked about a board that has been routed on 45 Degrees.
Regards,
Maqbool
Why do you want arcs instead of 45 degrees?
I work on Xilinx Load/Test Boards. These are boards with high speed interfaces.
Also there are some test Platforms : Teradyne J750, Credence Sapphire, Teradyne Integra Flex, Agilent V93K etc
A 90 Degree or 45 Degree Band increases the width of Track at point of Band for a very short period. It increases the reflection and signal rise time. It behaves like a capacitive load with the transmission line. Round corner maintains the width of the track and is good for the health of high speed signals.
Regards,
Maqbool
Only if your in the gigaHz otherwise it does not make any difference...
