devonsc
charging sealed lead acid 12v battery +circuit
Would like to ask the following matters:
Whats the difference or result of the following matters? Is it possible? Assume it is a 12V battery.
a.) Charge using a DC/DC converter. Boost or buck the voltage level to an apropriate level before applying to the battery.
b.) Charge by simply applying a power supply of 12V to 14V.
c.) With a low voltage, I amplify the voltage using a transistor before applying it to the battery for charging.
d.) With a low voltage, I amplify the voltage using a transconductance op-amp before applying it to the battery for charging.
With all these cases, despite considering the efficiency, can I say that all the above will also charge the battery? As long as I apply a higher voltage to the battery for the current to flow to the battery. At this point, ignoring the amount of current flowing into the battery for charging. Just wondering....Confused.
Sorry, if everything mentioned above are nonsense...
