power signal of waveguide port in HFSS
lak30
Junior Member level 2
I would like to know how can i inject a signal of power 1mWatt to the waveguide port of a circuit instead of the default value of 1 Watt.
regards.
Go to menu HFSS->Fields->Edit Sources...
The Magnitude of the signal injected at the waveport is set to 1 by default. change this to 0.001.
// Staffan
this is true for HFSS 8.5, but i have HFSS V9.2, and there is no menu HFSS->Fields->Edit Sources .
regerds
lak30
In HFSS V9.2 setiings, you are looking, just here :
YourProjectName/HFSSModel/Field Overlays/(Right Button Click) -->Edit Sources
I am using ansoft hfss v9.2, and there is a HFSS->Fields->Edit Sources...
For sure.
