How to use SBL1 double balanced frequency mixer ???
nikhilsigma
Full Member level 2
Delhi, India
I need to find the difference of two frequencies, so I am trying to use SBL1 double balanced mixer...
I was giving 5Vpp,1MHz on LO & 3Vpp,1.1MHz signal on RF frequency from function generator....so I should get 2.1MHz and 100KHz....but the signal i am getting is having 2.1MHz as the lowest frequency signal and another high frequency components but 100KHz was totally missing !!!
Circuit I have Build :
SBL1 Datasheet :
https://www.google.co.in/url?sa=t&r...=h7vESbnYLx7Rd9bJwViYgQ&bvm=bv.43828540,d.bmk
Please help....
If your SA cannot see down to 100kHz, place at the output of the mixer a simple LPF to let only 100kHz to pass. Terminate the LPF in concordance, and measure the voltage over the load to find the equivalent power level
