Setup time failure detection
rogger123
hi,
Can someone give me some methods to identify setup time violations after the chip is fabricated... any techniques to know if it is a setup or a hold time violation??
rogger123 said:
hi,
1. Setup time violation:
Slow down your chip clock freq., if OK, then it is setup time violation.
2. If slow down still failed -> hold time violation.
But some time it is due to power problem, so, raise up or down your chip working
voltage can give you idea about failure reason.
hi, rogger123
Why not to check the STA with your netlist after P&R?
Is there any way to locate a setup time violation in the chip(after the chip is fabricated)... meaning identify the flip flop which had the setup time violation?
Usually, when you create your design, there should be lots of debug bus or status check points, you can check which block failed in running chip.
It's really not easy to make sure which DFF has violation.
abner said:
rogger123 said:
hi,
If there are realy some hold violations, the silicon will be a garbage.:)
in real test process , setup and hold time check are all standard function of ATE.
you can inquire some test engineer
you must use PT to do STA first,
after fabricated,it's about test process;
1. get star rc file and rerun the STA
2. slow down your work Frequency and test again
3. increase you chip temp and check if there are hold time failure
but for most situation, hold time failure couldn't let whole chip failure.
Please do STA use Prime time,
then all violations may gone
do testing on both the fast parts & slow parts.
Yes , and Use "minmax case analysis" ..in primetime..
