PWM Frequncy Problem
rmrps
Member level 2
_FOSC(CSW_FSCM_OFF & XT_PLL8);
_FWDT(WDT_OFF);
_FBORPOR(PBOR_ON & MCLR_EN & PWRT_OFF);
_FGS(CODE_PROT_ON);
void Delay(unsigned int del);
int main(void)
Delay(50000);
Delay(50000);
Delay(50000);
Delay(50000);
Delay(50000);
TRISE=0x00;
PORTE=0x00;
PTCON=0x8004;
PTMR=100;
PTPER=199;
IPC9bits.PWMIP=1;
IFS2bits.PWMIF=0;
IEC2bits.PWMIE=1;
SEVTCMP=0x00;
PWMCON1=0xFFF;
PWMCON2=0x207;
DTCON1=0x4C4C;
DTCON2=0xFF;
FLTACON=0xFF80;
FLTBCON=0xFF80;
OVDCON=0xFF00;
PDC1=0x0A;
PDC2=6553.6;
while(1)
Delay(50000);
Delay(50000);
Delay(50000);
return (0);
while(--del);
Hi friends this is my code for generating pwm pulses it is generating 275hz pulses but i want 20khz pulses there is no changes while changing PTPER value Same frequency only coming how to change frequency of pulses i am using 16Mhz PIC30F6010A controller please give me guidelines where to change the code for generating 20khz pulses thanks in advance
