Results 1 to 7 of 7
    Junior Member level 2
    Points: 133, Level: 1
    Oct 2012
    20
    133
    ERROR(SPMHCS-1): Symbol is missing a refdes.
    Hello all,
    I am trying to draw the pcb foot print of mini usb type b. When I save the symbol it says ERROR(SPMHCS-1): Symbol is missing a refdes.
    Can some1 please help me.
    Thanx & Regards
    Here is the zip file with .dra and an image of the usb mini type b.
    Advanced Member level 2
    Points: 3,989, Level: 14
    Apr 2010
    Chennai,India
    615
    3,989
    14
    Re: ERROR(SPMHCS-1): Symbol is missing a refdes.
    when you create library you may be forget to give ref des,here i mention,it is not available delete library and create ones again ,
    kapil
    Points: 5,545, Level: 17
    Dec 2006
    India
    515
    5,545
    17
    you do not have to delete library in main window select *.dsn file than right click >> edit object propertiee
    now in this window in Comp Ref column check the part which does not have any footprint assigned to it and than give it some ref des
    Oct 2012
    20
    133
    Actually I am getting this error in PCB editor and not in capture. Here is the Screen shot.
    And here is the USB which Im trying to draw the PCB foot Print.
    Dec 2006
    India
    515
    5,545
    17
    You have to add ref label to footprint before saving it, you can find some documents on internet regarding adding ref des in allegro
    Full Member level 1
    Points: 1,814, Level: 9
    Feb 2012
    INDIA
    118
    1,814
    9
    Actually you have to add refdes for that footprint.
    open the footprint(.dra).
    go to layout-labels-refdes and assign refdes in the class and sub class you need it.
    please have a look of the attachment.
    after that save the symbol(.dra) and try.
  7. #7
    Oct 2012
    20
    133
    Thanx all i got it done.
