+ Post New Thread
Results 1 to 4 of 4
  1. #1
    Newbie level 6
    Points: 72, Level: 1
    Join Date
    Oct 2012
    Posts
    11
    Points
    72
    Level
    near module syntax error in model sim using d ff
    module dff(q, q1,d,d1,clk,reset);
    output q,q1;
    input d,d1,clk,reset;
    reg q,q1;
    always@(posedge reset or negedge clk )
    begin
    if(reset)
    begin
    q=1'b0;
    q1=1'b0;
    end
    else
    begin
    q=d;
    q1=d1;
    end
    end
    endmodule
    this is my code i getting syntax error in first line of in model sim please rectify that
    •   AltAdvertisment
  2. #2
    Full Member level 6
    Points: 1,708, Level: 9
    ads_ee's Avatar
    Join Date
    Oct 2012
    San Diego
    Posts
    328
    Points
    1,708
    Level
    9
    Re: near module syntax error in model sim using d ff
    I don't get any errors compiling in Modelsim SE 64 10.1b.
    I just copied your text into the file dff.v and ran:
    vlog dff.v
    vsim dff
    and it didn't throw any warnings or errors.
    Now on the other hand you should use non-blocking assignments in your clocked always block as this represents HW.
    If you don't know the difference read the following:
    http://www.sutherland-hdl.com/papers...ng_assigns.pdf
    Also you should use the C like syntax for the port definitions, so you don't have to keep repeating the port names.
    module dff (
    output reg q, q1,
    input d, d1, clk, reset
    etc..
    Regards,
    -alan
    1 members found this post helpful.
    •   AltAdvertisment
  3. #3
    Advanced Member level 3
    Points: 6,295, Level: 18
    Achievements:
    Created Blog entry 7 years registered
    Join Date
    Dec 2011
    Fremont, CA, USA
    Posts
    767
    Points
    6,295
    Level
    18
    Blog Entries
    Many times when you get an error on what seems like a perfectly fine line of code, it is the line(s) or file before it that is causing the problem. It would really help if you showed the actual error message.
    Dave Rich
    Senior Verification Consultant
    Mentor Graphics Corporation
    •   AltAdvertisment
  4. #4
    Newbie level 6
    Join Date
    Oct 2012
    Posts
    11
    Points
    72
    Level
    ya sir but i also do that in xilinx iam getting no errors
    im doing project on digital pll in 3-10 ghz range .so im using
    dff as my phase frequency dectector .one input is clk and other
    input is dco clk .i dono how to take the output.please help me sir.
    sorry sir i saved the file as vhd so that only im getting error
    thank u
