How to use the ASIC libraries during synthesis (Synopsys)?
peen1
the temperature in asic libraries
I had some questions about how to use the ASIC libraries during synthesis (synopsys).
I have a fast.db, slow.db and a tpz.db The fast and slow define the cell while the tpz has the pad information and some wire load models. The fast and slow libraries also have wire load models.
Which wire load models should be selected and how do I use the pad information for my synthesis.
How do I tell the tool to select the best model it seems fit?
Is it possible for the tool to mix the fast and slow libraries and choose the fast cells only when required, to fix the slack. I heard that ambit can do this.
Thanks in advance!!
Re: ASIC libraries
Thanks in advance!!
Hi peen1:
For synthesys, we normally use the slow lib because we need to fix the slack of
set-up, and leave the slack of hold to the backend tools.
wang1
Re: ASIC libraries
Since Pad cells are instatanced directely. The pad ring module is only linked in top level during logic synthesis.
ASIC libraries
1.select slow.db as target library , tpz.db is set as link library;
2. you can use wire load model in slow.db
Re: ASIC libraries
The wireload selection depends on the size of the design...
for eg in tsmc 13u lib
tsmc_wl10 is used for design of approx 10kgates
tsmc_wl50 is used for design of approx 50kgates
For more accurate results.. u have to genrate a custom wirelaod model for your design with primetime
fast and slow are only operating conditions... however you synthesize the gate which going to be in slicon is the same.... slow library assumes your chip operates in worst conditions like high temperature(125 degree typicaly) and lesser Vdd.
if you are talking about Multi Vth design... may be ambit can do...
though power compiler is the best option
Re: ASIC libraries
The fast and slow library can be used in Primetime for both case timing analysis.
Re: ASIC libraries
how about 50k+ gates?
