+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Newbie level 5
    Points: 354, Level: 4
    Join Date
    Nov 2011
    Posts
    10
    Points
    354
    Level
    How to compare netlist from Proteus ARES and ISIS ?.
    Hi All,
    Once again i like to raise this question.
    I am using ISIS for schematic design and ARES for PCB design,
    I want to do final netlist cross check by taking out the netlist file from ISIS and ARES and comparing it.
    But what the problem is both the files are in different format and the netlist priority names are also found different.
    Is there any way to do this?
    Kindly help.
    By this checking procedure i can Cross check the netlist which will avoid unwanted multi connections to the same net.
    Thanks in Advance.
    Rem
    •   AltAdvertisment
  2. #2
    Administrator
    Points: 38,102, Level: 47
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    alexan_e's Avatar
    Join Date
    Mar 2008
    Greece
    Posts
    11,892
    Points
    38,102
    Level
    47
    Blog Entries
    Re: How to compare netlist from Proteus ARES and ISIS ?.
    I think you didn't follow the proper order which is to make the schematic and press the ARES button to open the schematic netlists in ARES and then place and connect the components.
    If you use that way then as soon as you make a change in the schematic and press the ares button (make sure that the current work in ARES is saved first) it is reflected in the pcb (a component addition, a new connection or the deletion of a connection etc.)
    I have no idea if it is possible to make this connection between the schematic and pcb wen they are not connected form the start.
    Please don't make requests for help in private using PM. Create a thread in the forum so that other members can benefit from the posted answers.
    Consider reading this before posting : How To Ask Questions The Smart Way
    •   AltAdvertisment
  3. #3
    Newbie level 5
    Join Date
    Nov 2011
    Posts
    10
    Points
    354
    Level
    Hi alexan_e ,
    Thank you for your reply.
    Am following the same order as u had mentioned.
    Actually wt i do is i pull out the netlist in Schematic ISIS and ARES in two .xls files and do comparison .
    As the net from the ISIS and ARES are correctly connected same net or not, pin count, any NC pins , any Dangling lines or net etc.
    For this the Format of both netlist are little bit different. i need to work a while to make it clear and do my checks.
    for this am in search of some easy procedure or shortcuts.. and am here...
    I really thank you for your reply and support.
    thank you.
    Rem
