+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Points: 766, Level: 6
    Join Date
    Jul 2009
    china
    Posts
    Points
    766
    Level
    help! what is the equivalent model of the headphone? low res like 32 or 20 ohm series
    I just want to design a audio dac, architecture: sigma delta DAC + class D driver
    I don't know the equivalent model of the headphone
    if no LC filter is used on pcb,is class D still work? i mean if we can hear the voice normally?
    •   AltAdvertisement
  2. #2
    Advanced Member level 5
    Points: 25,337, Level: 38
    Join Date
    Dec 2010
    Southampton and holiday cottage in Wensleydale (UK)
    Posts
    4,863
    Points
    25,337
    Level
    38
    Re: help! what is the equivalent model of the headphone? low res like 32 or 20 ohm se
    I would think there will be an inductive component, 100s of micro henries? If there is no on board filtering, the leads will radiate the switching frequency which could displease those around you.
    Frank
    •   AltAdvertisement
  3. #3
    Super Moderator
    Points: 261,409, Level: 100
    Awards:
    1st Helpful Member
    Join Date
    Jan 2008
    Bochum, Germany
    Posts
    45,676
    Points
    261,409
    Level
    100
    Apart from the EMI problem, I doubt that the inductance of usual dynamic headphones will be suffcient to act as a low pass filter.
    Generally, you'll rather want to measure the impedance of a typical head phone than guessing about it.
