Results 1 to 6 of 6
    Advanced Member level 2
    Points: 21,612, Level: 35
    Sep 2004
    661
    21,612
    35
    Difference between 'deterministic' and 'stochastic' ?
    Would anyone pls advise the difference(s) between the 'deterministic' and 'stochastic' process/model/etc ?
    Full Member level 3
    Points: 2,542, Level: 11
    Sep 2004
    Within arm's reach
    162
    2,542
    11
    Re: Difference between 'deterministic' and 'stochastic' ?
    A deterministic model/approach has predefined results like we know the possible input.On the other hand a stochastic model/approach has a real time input so that it is not known priorly.A possible example can be the diffeence between digital filters like IIR/FIR and Kalman filters.
    drdolittle :)
    Full Member level 3
    Points: 6,660, Level: 19
    Aug 2004
    180
    6,660
    19
    deterministic = non-random (everything values, behavior known exactly)
    stochastic = random (something are not known exactly, only explained in terms of probabilities)
    Sep 2004
    661
    21,612
    35
    So, do you guy agree that it's more challenging to model stochastic process?
    Full Member level 5
    Points: 3,928, Level: 14
    asic1984's Avatar
    Nov 2003
    257
    3,928
    14
    hi
    stochastic process is more difficult to be modeled and simulated..........and in complex systems u may have to neglect some variables to be able to use the model
    Full Member level 3
    Sep 2004
    Within arm's reach
    162
    2,542
    11
    Exactly modeling a stochastic model involves difficulty as only here the adaptation is brought in.whenever the system is said to possess adaptive nature framing a model to explain its behaviour becomes tougher.The best example for adaptation is modeling synapse in neurons which is subjected to adaptation.
    drdolittle :)
