+ Post New Thread
Results 1 to 5 of 5
  1. #1
    Junior Member level 1
    Points: 306, Level: 3
    Join Date
    Jan 2012
    Posts
    15
    Points
    306
    Level
    want a solution for Variable O/P voltage SMPS
    sir,
    I want to design a SMPS with variable O/P voltage eg. 4-30V with variable current eg. 0-3A.
    So sir I am confuse which topology is suitable for this application. please suggest me some solution. And if u have any reference then please forward me.
    •   AltAdvertisement
  2. #2
    Full Member level 4
    Points: 2,346, Level: 11
    Achievements:
    Created Blog entry 7 years registered
    manishanand14's Avatar
    Join Date
    Sep 2011
    Bangalore ,India
    Posts
    203
    Points
    2,346
    Level
    11
    Blog Entries
    Re: want a solution for Variable O/P voltage SMPS
    It's a switch mode power supply circuit
    Click image for larger version.
    Refer datasheet of LM2576.
    Genius is eternal patience.
    •   AltAdvertisement
  3. #3
    Advanced Member level 5
    Points: 38,590, Level: 48
    Achievements:
    Created Album pictures Created Blog entry 7 years registered
    Tahmid's Avatar
    Join Date
    Jun 2008
    Silicon Valley, California, USA (from Dhaka, Bangladesh)
    Posts
    4,758
    Points
    38,590
    Level
    48
    Blog Entries
    22
    Quote Originally Posted by maheshjalgaonkar View Post
    sir,
    You can do one of 2 things:
    1) For variable output voltage, adjust the duty cycle of the primary side PWM controller.
    2) Have the output voltage fixed and use an adjustable switching voltage regulator.
    I would say that the 2nd choice is better. If you choose choice 1, the required change in duty cycle is too large. Also keep in mind the automatic duty cycle change to compensate for line and load variations.
    So, you can have a fixed output voltage greater than 30V (eg. about 40V) and use a suitable switching regulator.
    Hope this helps.
    Tahmid.
    1 members found this post helpful.
    •   AltAdvertisement
  4. #4
    Join Date
    Jan 2012
    Posts
    15
    Points
    306
    Level
    Thanks for solution but i want adjustable current also and i want linear O/P(ripple free) so i was thing to used series pass transistor to be used at O/P of SMPS so is that ok with this 2nd option. And one more thing i am considering both of this options are for flyback topology .
  5. #5
    Join Date
    Jan 2012
    Posts
    15
    Points
    306
    Level
    For variable output voltage, i want to adjust the duty cycle of the primary side PWM controller So i need help on this topic if u can suggest any PWM controller for this application or if it just a matter of transformer design then what will be the value i should consider while designing Transformer like Duty cycle, switching frequency, Bsat.
