about cic filters advantages of integrating and combing at lower sampling rates
kannan2590
Member level 4
india
what are the advantages of integrating at higher sampling rate and for comb filters lower sampling rate in cic filters
Since Z-domain transfer function of CIC filter is:
where
N=order of filter
M=Differential Delay (usually M=1 or 2)
R=Decimation Factor
So while implementing CIC as decimation filter Integrator is followed by Down Sampler and then by Comb filters, the advantage is that now you need only "M" delay elements as compared to "M*R" required for earlier implementations which results in less area and low power consumption. As shown in following figure: (Note: M=1 in figure)
Hope this is helpful.
where
N=order of filter
R=Decimation Factor
actually i want to ask you a question that what is the difference between differential delay and ordinary delay.this differential delay M=1 or 2.
