+ Post New Thread
Results 1 to 3 of 3
  1. #1
    Member level 4
    Points: 513, Level: 4
    Join Date
    Sep 2012
    india
    Posts
    77
    Points
    513
    Level
    about cic filters advantages of integrating and combing at lower sampling rates
    what are the advantages of integrating at higher sampling rate and for comb filters lower sampling rate in cic filters
    •   AltAdvertisment
  2. #2
    Member level 3
    Points: 620, Level: 5
    Join Date
    Oct 2012
    Posts
    54
    Points
    620
    Level
    Re: about cic filters advantages of integrating and combing at lower sampling rates
    Since Z-domain transfer function of CIC filter is:
    where
    N=order of filter
    M=Differential Delay (usually M=1 or 2)
    R=Decimation Factor
    So while implementing CIC as decimation filter Integrator is followed by Down Sampler and then by Comb filters, the advantage is that now you need only "M" delay elements as compared to "M*R" required for earlier implementations which results in less area and low power consumption. As shown in following figure: (Note: M=1 in figure)
    Click image for larger version.
    Hope this is helpful.
    •   AltAdvertisment
  3. #3
    Member level 4
    Join Date
    Sep 2012
    india
    Posts
    77
    Points
    513
    Level
    Quote Originally Posted by Eminent.Engineer View Post
    where
    N=order of filter
    R=Decimation Factor
    actually i want to ask you a question that what is the difference between differential delay and ordinary delay.this differential delay M=1 or 2.
