How can we meet timing ("SLACK MET") and none zero "DESIGN RULE COST" together?
alexhugo
Junior Member level 3
How can we meet timing ("SLACK MET") and have none zero "DESIGN RULE COST" together?
I am synthesizing a circuit (using DC) and I see that the timing is met (SLACK MET) by using report_timing. The problem is that "DESIGN RULE COST" is not zero. As far as I know none zero design rule cost means that the timing is not met.
What am I making wrong? How is possible to have these two together?
Thanks
Alex
Re: How can we meet timing ("SLACK MET") and none zero "DESIGN RULE COST" together?
Hi Alex,
DRC is the violation in your max_cap or max_tran values and nothing to do with slack. DRC is given more importance than timing. U have to rectify the DRC error and only then u have to c the slack.
I know how DRC works in analog design but I don't know where to start working on it and fixing it in digital circuit.
Could you please help me and let me know where I should start and what I should do to fix the DRC issue in my digital ASIC design!?
