[SOLVED] VSC7398 - PHY works, but switch doesn't switch any packet to other port
coolrob
Poland
Hello!
I'm trying to set up a 1Gbit switch, built witch VSC7398 from Vitesse. I have a mictrocontroller on this same PCB board, which is connected with VSC7398 via SPI, so I can read and write registers in VSC7398. Actually PHYs works with autonegotiation (LEDs indicate current speed), but there are not any transmission between ports :sad: MACs are configured as 1Gbit and I connect 1Gbps devices to my switch. I tried with 100Mbps but result was the same. What is strange, when I read the CHIPID I get following value: 0x273850E9, so it indicates that my chip is VSC7358! I use following initialization procedure:
    SwSpiWrite(_SIPAD_ADDR, 0x00);  // set dummy bytes to 0
    reg = SwSpiRead(_CHIPID_ADDR);    // read chip's ID
    // Memory initialization
    uint32_t memId;
    for( memId = 0 ; memId < 15 ; memId++ )
        if( memId != 6 && memId != 7 )
            SwSpiWrite(_MEMINIT_ADDR, ( (uint32_t)0x1010400 + memId ) );
            delay(20000);
    delay( 30 * 20000 );    // wait 30ms
    // Format memory
    SwSpiWrite(_MACACCESS_ADDR, 5);   // clear MAC table
   [COLOR="#FF0000"] SwSpiWrite(_VLANACCESS_ADDR, 3);  // SwSpiWrite(_VLANACCESS_ADDR, 5) was before!!![/COLOR]
    delay( 40 * 20000 );    // wait 40ms
    // set all buffers as 20kB
    int i;
    for( i = 0 ; i < 8 ; i++ )
        SwSpiWrite( (_Q_MISC_CONF_ADDR | (i<<8)), 0x80000000 );
        delay(80);   // wait 4us
    // release PHY reset
    SwSpiWrite(_GLORESET_ADDR, 2);
    // from PHY Configuration.pdf
    int port;
    for( port=0 ; port < 8 ; port++ )
        SwSpiPhyWrite(port, 31, 0x2A30);
        phy_write_masked(port, 8, 0x0200, 0x0200);
        SwSpiPhyWrite(port, 31, 0x52B5);
        SwSpiPhyWrite(port, 16, 0xB68A);
        phy_write_masked(port, 18, 0x0003, 0xFF07);
        phy_write_masked(port, 17, 0x00A2, 0x00FF);
        SwSpiPhyWrite(port, 16, 0x968A);
        phy_write_masked(port, 8, 0x0000, 0x0200);
        SwSpiPhyWrite(port, 31, 0x0000);
        SwSpiPhyWrite(port, 18, 0x0048);
        phy_write_masked(port, 22, 0x0240, 0x0FC0);
        phy_write_masked(port, 20, 0x4000, 0x6000);
        SwSpiPhyWrite(port, 31, 1);
        phy_write_masked(port, 20, 0x6000, 0xE000);
    // MAC configuration
    for( memId = 0 ; memId < 7 ; memId++ )
        switch ( memId )
            case 0:
              SwSpiWrite( ( _MAC_CFG_ADDR | (memId<<8) ), 0x10070184 ); // 0x90010444 - off, 0x10050444 - 10 lub 100 full Duplex, 0x90010444 - 10 lub 100 half duplex, 0x10070184 - 1Gbit
              break;
            case 1:
              break;
            case 2:
              break;
            case 3:
              break;
            case 4:
              break;
            case 5:
              break;
            case 6:
              break;
            case 7:
              break;
    // LEDs configuration
    SwSpiPhyWrite(0, 0x1B, 0x8601);
    SwSpiPhyWrite(1, 0x1B, 0x8601);
    SwSpiPhyWrite(2, 0x1B, 0x8601);
    SwSpiPhyWrite(3, 0x1B, 0x8601);
    SwSpiPhyWrite(4, 0x1B, 0x8601);
    SwSpiPhyWrite(5, 0x1B, 0x8601);
    SwSpiPhyWrite(6, 0x1B, 0x8601);
    SwSpiPhyWrite(7, 0x1B, 0x8601);
    // set MAC mask - turn on the packets transmission
    SwSpiWrite(_RECVMASK_ADDR, 0xFF);
Can anybody help me?
Problem is fixed - small mistake in code. I marked it by red color in previous post. Switch works well :)
